Today I finally got round to fitting the higher output H7 bulbs that have been sitting on my shelf for a couple of months. I was finally driven to it by one bulb blowing and the amber warning light coming on.
First I checked the owner manual - sounds dead easy - wheel over onto full lock, open the little hatch, remove headlight cover, remove bulb, insert new, reassemble.
Why doesn't it tell you that the little hatch only opens if you turn the catches the opposite way to the description, the headlight cover is almost impossible to remove, the bulb holder goes back in but doesn't lock into place, and the headlamp cover is impossible to get back into place without accidentally popping open the bonnet ?
Oh, and the only way to get realistic access is to take the wheel off :dizzy: Luckily my trusty old E46 could supply a wheel brace and jack.
