Hi,
Like many others, I have suffered wet carpets during my ownership of the Zed, and have spent years in my quest to find the source of this mysterious giver of life to the mould on my carpets and the rust beneath them.
Anyway, following on from a suggestion by another member on the Forum - apologies, I don't have the o/p details - I bought a 1m (?) packaged length of 4.7mm clear washer tubing from Halfords and then inserted it up as far as I could up the rubber drainage channel. The opening for this is at the front of the door at window sill level. The reasoning behind the member's original post was that over time, the rubber drainage channel in the door loses it's rigidity, becomes compressed and restricts the flow of water, which then finds an alternative path to drain, in this case eventually into the carpeting.
I went to reach for the rolled up towel in the passenger footwell the other day expecting it to be soaked (again) after all the recent wet weather and was amazed to find it completely dry.
I fitted both sides last September. I sprayed some PTFE stuff on the tubing first to help get it up as far as it would go, and then cut it about 3" below the insertion point.
Not saying this will work for everybody, but it seems to have cured my problems on both sides.
For the time being.......
Robert.
Robert.
