I bought an early 2.2 a few months ago and had the emissions light come on straight away, found a split hose which I replaced and cleared the fault, no problem for some time and then the light started to come on when on motorway trips after about fifty miles and usually while driving in the 50 limits when backed off in fifth gear, so tried doing the 50 in fourth and no light came on but a check still revealed that it is running weak on bank 1 & 2 in the low range so how can I adjust this? Air filter is clean and I can see no other air leaks, engine pulls well no coughing etc.
Also, although the clutch seems to work fine it will indicate over temp and excessive slippage as a fault code, the only time it slips is if I hit the accelerator and am slow dropping the clutch so understandable but I understand that there is a valve to slow the fluid return and prevent stalling something which some modify, is this likely? It actually bites well and it's easy to spin the wheels so apart from the codes I wouldn't know of such a problem, has anyone had experience of this?
Third admittedly minor problem, is the indicators, sometimes when indicating I can hear the usual relay sound from behind the dash, sometimes it is silent, sometimes it changes during the operation! But, the lights are operating normally, so, is there a relay or a sound generator which can be replaced or do I need to check the instrument cluster?
