Water Water Water !!!!
RROB
Started to notice the car water temp wasn't right..... after last couple of drives..... no warm air
So last might i thought id have a look checked rad (had to top up) left car running for 15 mins and then POP ! water oissing out from rad area.....
water now ecaping from bottom right of rad somewhere.....Ive been told a weak spot i a bung on the rad that can pop out ?
i dont know if its the bottom right hose untill i get her jacked up ?
Anyone had similar issues ?
Right when you stand looking at the front of the car, or right of the car ?
I'm guessing at a split expansion tank.
Check the top right corner of rad for a split that’s what happened to mine recently if not then header tank maybe
Fairly certain that on a 53 plate it will be a split expansion tank. Mine's an 03 plate and split in August last year. It's the number one culprit on a Zed of that age and in that location :thumbsup: 20170819_134642_Richtone(HDR).jpg
