Water trapped in frame
When is the outlet for this drain? The other side is easy, it has a flapper and drains in the engine bay. But the USA driver side is different. When I pour water into this drain, it leaks out the front and rear jack pad area.
I wrote a post on where the water gets into the frame. Solution is to drill holes into the jack pads..
Watch this you tube video..
https://www.youtube.com/watch?v=VAGxCttLlPY
Ewazix said:
It's worth checking the drains at the front, rubbish can build up in the front scuttle under the screen in the engine bay blocking the water drain-off tubes. Water then makes its way down inside the hollow structure to the sills. The first time I cleaned mine out about ten years ago the front drain was full of leaf compost! See this thread for details https://z4-forum.com/forum/viewtopic.php?f=2&t=40973&p=585592
Bumpy bump.... Drilling holes and removing rear roof drain bungs is unlikely to solve how water is getting in the sills, it flows back in to the chassis sections from the front. Blocked front drains under the bonnet and scuttle area are the most likely cause.
Check out this thread explaining about trapped water and where it gets in. https://z4-forum.com/forum/viewtopic.php?f=3&t=125168
