Hi Guys
Engine temp started going up quite a bit luckily was down the road from home, RAC came, the mechanic didn't think was water pump initially and plugged diagnostics which came up with water pump speed deviation intermittent. The heating is intermittent so when turned to hot is sometimes cold, not sure how this is linked?
Plan to get the pump changed. Just wanted to ask if it's advise able to get timing belt done while they're doing it. 99000 miled, z4 coupe 2006.
Faz
Faz
