Water leaking drivers side window
100% yes
Had the same on mine
Get the door card off to see what the seal is like and if it’s bad use some tec7 to reseal it
fairly easy job Dai-
Advisable to unhook the battery just in case you disturb the airbag- good practice to not get one in the face
Pop the handle cover off, the little cap in the interior door handle and the airbag plastic plug- that reveals 4 T30 (I think) screws
Take the tweeter pod off, undo the bolts
Working from the bottom of the door pop the door card off, the top will resist but prevail!
Take care with the door handle cable, this unclips, undo the associated switches to get the card away from the car
Then you can inspect and repair the membrane
Drop me a line if you get stuck
Stuart
O/P: The guy in this video explains how to adjust the windows in a Z4, as well as, how to adjust the door so it will fit tighter to the car.
https://www.youtube.com/watch?v=xLQ6VKx7_Fo&list=PLdqguOMcgFtvMRNkSkpKOp2O__zlvt2C5&index=18
