Hi all, I have a 2004 e85 which has water sloshing about in the front of the sill.
I have checked the rear drains and they are fine.
It has started coming in to the driver footwell and wetting the carpets.
I have Google searched and some have said the jacking point can stop water from draining out and by wiggling it by hand loads of water comes out.
I've also seen some have drilled the jacking points as a more permanent solution. My question is where in the pad should the hole be drilled, near the middle, anywhere on the sunken section?
Otherwise is it OK to just remove the pad and say keep it in the glove box when needed? If so is it just lever off with a screwdriver job or more complicated?
Mark
Mark
