Washers not working on 30i
Big Bad Boris
 Braintree
I discovered yesterday that my windscreen washers weren’t working, probably first time I’ve needed them since acquiring the car a couple of weeks ago. A little searching led me to a couple of historic posts which told me all I should know to fix the problem. Hence I’ve just finished removing, cleaning and replacing the washer reservoir, it was full of the predicted slimy residue with a delicious sprinkling of black mouldiness. I cleaned the heavily clogged filters and nicely cleaned out the reservoir.
Clearly this appeared to be the problem, the little filters couldn’t have been more blocked. I have just put it all back together in the car.....and it still doesn’t work :headbang:
I can hear a pump doing it’s thing, but neither the headlamp washers or windscreen washers are producing any fluid ( I did put the lights on). Just to confirm, the pumps appear to be just a push fit into the rubber washers, there are no clips or anything to hold them firmly in place?
Any suggestions for what to try next? Seems odd that neither system is working?
They should be protected by the filters in theory. But I suppose It’s possible some crud could have got in, can they be taken apart and cleaned out somehow?
This might sound weird but I had something similar on my old MGZT - emptied washer bottle and put in sparkling water and lemon juice, the lemon juice softened off the limescale crud (London water) and the sparkling water.. Just because its seemed like a good idea at the time (I was in sainsburys and their cheap bottled water was dirt cheap)
I did this not too long ago, the actual lines themselves might be blocked with crud too, mine was fixed purely by cleaning out the tank, but maybe put something strong in there to break down the crud in the tubes.
My old man was told to put Viakal in the washer bottle to clear out the tubes.
He left it in about 15 minutes, with not too much water, then operated the washers a few times, with a couple of minutes between each squirt to allow it to soak in more.
He did put poly bags over the jets though, to save potential paintwork damage.
The trick worked though. Cleared them a a treat.
Get an old toothbrush and gently scrub the nozzles on the bonnet, you can also strip a small piece of copper wire, twist the strands and poke the holes out.
Placing your mouth over the nozzle and blowing can also help (an excuse to kiss your car!!!!!).
Also worth parking on a piece of dry ground, just pull the wash lever and let it run for a few minutes, if you have any leaks you will see it on the floor, the level in the tank should also drop, if it does not then the pump is going round but not pumping....
Thanks chaps, I think I have some “Cillit Bang” bathroom black mould remover under the sink somewhere, that’s probably going to work better than Vikal, assuming it is gunged up with the same black bits and slime I removed from the tank and filter yesterday.....rather than limescale.
I will try the toothbrush and french kissing technique first, sounds a lot more fun :wink:
One more question, I assume the headlamp washers “pop out” to do their thing? I haven’t seen them do that as yet, should they still pop out even if there as no water getting through?
It is possible to code the headlight washers to not pop out out & spray screenwash over your highly polished bonnet :?
Quick update.....
So I used the toothbrush. Then decided to top up the reservoir for a test, which promptly left me with wet feet, looks like I didn’t quite seat the rear pump properly so fiddled with that to make sure it was fully engaged and hey presto water spraying all over the windscreen ..a beautiful sight.
Still not a peep from the headlamp washers. Rob - How can I tell if they’ve been “coded out” ?
I have read some people pull the fuse for the same reason, I will check that tomorrow.
Big Bad Boris said:
Quick update.....
You’d have to connect to Carly or similar to see if it can be coded back into normal operation, it’s possible to reduce the frequency of headlight washes per windscreen wash as well.
Some mot testers will overlook something like this as it’s hardly compromising safety :thumbsup:
