Hi all
My washer jets stopped working back end of summer, and as the car has been parked up these last few months it's been a job that was easy to put off. Now my MOT is due in 7 days I thought I should get on with it!
I took the reservoir tank out, degunked it and the filters (they were pretty bad but I managed to get rid of the vast majority of the crud) and put everything back together. Nothing coming out of the jets! Took it all apart again, reassembled and the jets were weak to say the least. Then....they just stopped working altogether ie. the pumps weren't running but the wipers were moving. Thinking I'd blown something I turned the engine off, left it a few minutes and this time disconnected the hose running to the windscreen, just to check the motor was ok. It seemed fine, spraying water with no issues. So, I reassembled and this time had a stronger stream with the bonnet up. Bonnet down, weak again but I persisted with running the tank through, and then the motor stopped running again! Turning the engine off and on made no difference.....wondering if I've blown a fuse or something? And I'm a bit stumped now. The motors seemed ok (although the light wash didn't seem to work at all) and I don't think the pipe was blocked, it just seems very temperamental. Is it worth replacing the hose to the windscreen and the tubes? Assuming the motors still run (everything got a bit wet so I'm letting things dry out a bit)....
Any advice appreciated - apologies for the wall of text, I just can't seem to notice a pattern to its behavour.
