Washer fluid reservoir leaking
step_change
 Planet Earth
Hi not been in the Z for a week or so and started her up this morning and I gets a washer fluid level warning. Odd I thinks since I filled it up two weeks ago. Reversed out of the garage and lo and behold a puddle of water on the garage floor. I looks at the washer reservoir and seems to be leaking at the very bottom at the back where the hose and pump assembly are. Not sure at this stage if it's the hose, the pump or maybe a seal/gasket. Drip-drip-drip with a drip every three or four seconds.
Any thoughts please? I have it on extended warranty but no point paying £100 excess if something I can do myself. Seen a previous thread on this that talks about washing the washer bottle out.....
Thanks, Steve
I had something similar after I bought my 2016 zed - it had possibly sat for a while before I bought in in November (always buy convertibles when the weather's bad).
I got through 10 litres of screen wash in a fortnight - jiggled every hose I could find whilst running my hands along the hoses trying to find a leak, nothing, no staining or trace marks, because it had rained quite a bit, I could see any puddles, but it stopped afterwards, I'm guessing either something worked slightly loose and without knowing I'd pushed it back or some grot had plugged the leak (unlikely as she'd only done 33k). Third option was the car has become self aware and was testing me.
Thanks, Steve
Did you ever figure out how to sort this?
I removed the washer bottle and thoroughly cleaned it out with a bottle brush. I wiped and rinsed the hoses. Put it all back together and it was all fine. 30 minute job.
Hopefully this might help:- https://z4-forum.com/forum/viewtopic.php?t=135595
