Bing said:stehanson, see this thread, 3rd post down -
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=33049&p=446940#p446940
There is a link in srhutch's signature for future reference.
markeg said:B63.12.6.928.413 and B63.12.6.928.414
They're £10.34 each from Sopers, Lincoln (quote the forum to get a discount)
Tapatalking...
tomTVR said:Nice writeup, i have this problem so will attempt the same. Just a couple of questions :
1) I read in another thread that really streamed up lights are left with nasty watermarks on the inside, was this a problem?
2) I like the sealant idea but are there not products available which assist with rubber seals? I actually used KY jelly for a similar problem on our inflatable boat which seemed to work for an afternoon, however not sure if would last long term.
markeg said:You might also want to check that the retaining section on the headlight isn't bust - they are a weak point on the headlight so can let water in - and check that you have all 3 grommets on the rear (B63.12.6.928.409). These aren't cheap though, they're £8.74 each!!
Tapatalking...
markeg said:+1 on Sopers, they post at no extra cost
For the grommets, see the photo below - the red ring shows the grommet positions
Tapatalking...
stehanson said:markeg said:+1 on Sopers, they post at no extra cost
Thanks for that, (pics) will order the part from Sopers in that case
Tapatalking...
