Warranty Work: New starter motor, Oil top up and brake fluid
Beancounter1980
Hi Guys,
dropped the car off today for warranty work.
I need a new starter motor due to the grinding noise at startup. Sounds horrible sometimes!
Also they stated i need a brake fluid change. So i said fine. However I refused the oil top-up at £22
Top up? How many litres does that equate too? I'm scouring the net atm for the cheapest 5W30 (Castrol edge that is!) i can find...
Tbh i think its a bit of a fallacy as i picked the car up 2 months ago with a full BMW Dealership service. I thought the N54 engine was ok for oil consumption.
If you indeed have a 3.0i in your sig (not 3.0si), thats the M54 engine mate. Yeah they do use a little oil sometimes, especially if driven enthusiastically or on short runs.
Id say mine uses around 1 litre every 2500miles. Some would say thats a lot, but it really isnt. Its well worth buying a 5l carton to keep at home for topups - make sure you check the level every 1-2weeks, as once the "Check Oil" light illuminates, its probably getting a little too low! :thumbsup:
gannet said:
Beancounter1980 said:
jamiez said:
It does, "roughly" via the oil check button
Where is this oil check button on a 2003 3.0i?
it is called a dipstick on ours :D
you just get a warning light when it thinks its low...
:D whoops!
I was thinking that! I think i'll pick up some 5W30 on the way home.
They also replaced the rusted hydraulic trunk joints under warranty too.
My dealer gave me a oil top up free, and the remainder of the bottle, when it went in for warranty work.
Mind you, it was in there often enough when i first got it.
All sorted now (I hope!) :)
