ph001 said:That's more than likely a wheel speed sensor. You need to read codes to find out which one if it's not obvious from a visual inspection.
This guide will show you everything you need to know...
https://www.pelicanparts.com/techarticles/BMW_Z4M/83-BRAKES-ABS_Wheel_Speed_Sensor_Replacement/83-BRAKES-ABS_Wheel_Speed_Sensor_Replacement.htm
[/quoteCould you possibly recommend a code reader for me to buy please
Good read.ph001 said:That's more than likely a wheel speed sensor. You need to read codes to find out which one if it's not obvious from a visual inspection.
Robert63 said:Thanks very much for the Pelican link very good. I am looking to keep my zed for some time to come, and it looks like an error code/diagnostic reader is going to be very useful. Of the ones that you have listed is there one that in your experience would be the one that would be of the most use.
