Warning lights Abs
Whizz2949
New member
Hi There.
I have just had fitted a reconditioned ABS Pump and it works.
My problem is the warning lights have stayed on.
I took my car to a BMW Garage and they said that my car has no problems at all but the warning lights cannot be removed because the car is picking up the doner cars chassis number. They said that When I have my car serviced I should always ask for a diagnostic check to make sure your ABS Pump is still ok.
How can you turn off the warn lights if s BMW Garage can't.
Will pull a fuse sort out my problem.
Help
Whizzy
I assume that is a chargeable service! :wink: :roll:
No, you will need to get the correct chassis number written to the DSC module. A competent BMW specialist should be able to do that. Even a competent diyer with the correct software should be able to do it.
Where abouts are you? There might be a forum member that is willing to help in exchange for cold beverages.
