Here, IMHO, is the clue to a dodgy sensor rather than big money - well, with a bit of luck.Jordnm88 said:However after turning the engine off, and restarting it seems to start fine, although today it took 3 attempts.
ekimj10 said:The book says:
"BMW Z4 E89 Roadster automatic transmission cog warning light - if this light illuminates during normal driving conditions it means that the transmission is overheating. Reduce your speed immediately and pull over at a suitable location so that the transmission can cool down again. You can continue your journey, but moderate your speed and exercise due caution. Have the system checked immediately."
Definitely worth having it checked out, hopefully just a sensor problem but letting the gearbox cool and the warning light going off doesn't sound like a faulty sensor. Best of luck.
GAZA62 said:Mines been doing this on and off a for a couple of years its normally after the cars been parked and I normally just turn off and restart if you do drive it just stays in one gear my mate is a BMW Tech so whenever he services my Z its at a BMW workshop so she gets plugged in every time and passes with flying colours but he has told me that you can get a lot of false readings but get it checked to be safe
Jordnm88 said:Dealer says they will diagnose it and lend me a FIAT![]()
to death
Jordnm88 said:first time it happened the car hadn't been driven for about 4 hours.
Second time it happened it hadn't been driven for about 12 hours (overnight)
Third time (today) it was about an hour after it had been driven... So it's fairly unpredictable!
Dealer says they will diagnose it and lend me a FIATin the event they need to keep it, but they're a 3 hour round trip away, I would rather get it diagnosed before I leave but not sure if anywhere will fit me in at the last minute tomorrow morning
