Wanted ; style 108s
jamie_z4
Veteran
As title looking to return the car to standard so after some 108s preferably tatty as I'll be re furbishing them and not bothered about tyres
Like the style of the car on the right :
Either based in North West England or willing to post
Thanks!
Jamie
Got a scabby set needing refurb, £200 willing to post but it will probably cost £40 with Paisley freight, unless you know better,
Thanks Ronnie
True standard are 135’s Jamie. The 108’s were optional.
Might help if your not fussed what you put on.
Mine came with 107s mate as its pre face
Weirdly I love mv2s on the e46s but not keen on them on the z4 but as you say... Open to options really! 18s anyway :)
Thanks Ronnie
Thanks Ronnie will bear it in mind see if anyone has any local first :)
I have a set coming off soon with new Avon ZZ5’s on them. They are dark grey in colour, but could do with a refurb. Would be looking to get around £400 for them.
I have a set near Manchester, pretty scabby and was going to refurb before selling but I frankly don't have the time now. I believe you're reasonably near by?
Hi mate how much and where abouts are you cheers
Wheels are in my parents garage, so M33 area. The centres have a small bit of bubbling on a couple but generally quite tidy, the outers are in real need of a refurb. No structural damage that I can tell, just cosmetically well worn as the clear lacquer has started flaking on all 4.
Now, one bolt is rounded off, so will need removing by means other than a spline bit. I was looking at getting some impact tools and a hex drive but never bothered and, now that I have my set of MV3s refurbed and with new tyres, know I'll never be bothered with doing them. All the other 79 bolts have been removed so the wheels can be collected as is (centres are still matched to respective barrels) or I can loosely bolt them back up again. As you're looking at refurbing I'll leave this to you.
Tyres are still good, around 4mm tread front and rear I believe, with a mix of ContiSport 5 and F1A2 tyres, each axle is the same but I cannot recall which one is which (ie front/rear).
As for price, say £180 collected?
I will have a set of 108s available next week. Good candidates for a refurb! Staggered set of 18s, 8J fronts and 8.5 J rear. Tyres are good Toyos on the front, knackered Potenza run flats on the back. Rears have had some welds; solid but scruffy work, on the inside of the rim. There is some paint blistering on all of them ( not an issue if you’re having a proper refurb) and some very minor kerbing on one. Best bit; all the rim bolts look ok, and haven’t been painted over by an over enthusiastic refurb artist. Not looking for big money; £150 would make me happy. Collect from North Staffs.
