klarky said:Is the fatter wheel worth the additional £100. I never bothered with mfsw as it was going to cost to much but £140 ish to retro fit seems reasonable, £245 for a new wheel thrown in seems a bit much to me, is it much more comfortable?
klarky said:Now you've done it, as I've carbon wrapped my interior the m wheel would look good to complete the dark look. Oh well will have to see how much I get paid next week lol
send Joe an email and he'll tell you,or have a look at the realoem website.playalistic said:I've got an SMG i.e. paddles on the wheel... Is there a separate part for this or does the usual M wheel work?
"I have undone the light switch centre and pulled it out slightly simply to make the plug easier to photograph. You do not need to do this. You can get perfectly good access through where the instrument cluster normally sits."
PawnSacrifice said:WIth a 2004 car you shouldn't need to worry about the extra cable and instrument cluster. So, basically you need the bits from the guide for:
1. Disconnect the battery for 20 minutes (important part - I went for coffee)
2. Remove the airbag (fiddly job)
3. Remove the old wheel and disconnect the cables
4. Plug in the cables for the new wheel - extra one for the MF
5. Fit the new wheel
6. Air bag on - connect cables and push into place
7. Connect battery
8. Test and glory!
I'm the same as you, a little cautious with mods, I just take close up pictures at each stage of dis-assembly in case I want to check what is where when I put it all back together. Most of the time I can do that from the camera LCD. This is a simple one though - and the result is surprisingly good, made a far greater difference than I was expecting![]()
navid.v said:Just to say a Big thanks to all who helped,and especially to you for putting my mind at rest![]()
I will take photos of each stage and hopefully upload here when it is done.
unplugged the battery at 12,waited till my lunch break and with a supervision of a mate,changed the wheel
klarky said:christ its a lot fatter! think ill be ording one next week then lol
