WANTED - Centre red brake light
bmwz4manchester
New member
Iam looking for a high level brake light in red for a z4 2003 if any 1 can help please let me know, this is the second 1 to split in less than 6 months.
Cheers colin
hi, welcome to the forum
where did you get the second one from? is it not under warranty.
there is a common issue on these with the nuts being overtightened. when you put it on put the nuts on with ur fingers as much as you can. then one 3/4 turn with a socket and it should do the trick.
there are also weaker springs available at bmw :thumbsup:
I just had to get a clear one from the dealer :x i ended up putting some loctite on the threads and doing what rudd said, think i left about 5ish mm of thread showing below the nut
bmwz4manchester said:
Still looking please if any 1 has one ?? cheers
Dan,
I've got one in perfect condition but wont be back in the UK until the first week in August. Can forward it then.
