Hi All,
Long time browser but only second time posting (1st was related to the soft close wiring issue in the boot with this forum help me resolve). Once again I find I need some help.
I have changed my tyres on my 35i from run flats to Goodyear Eagle F1's (with alignment and wheel balancing) around 3/4 months ago. I have noticed since this change i get some vibration through the steering wheel and brakes on certain roads. When driving this can be just through the steering wheel and under braking it will come through the pedal as well. Now for the tricky bit i can not get it to repeat if i try unless i am on the roads i know where it does it. I've put it on a break tester to see if the discs are warped but again there was very minimal difference on either side so doesn't seems to be the issue. Also under heavy braking on some roads no feedback is given. It seems odd but it happens on too many roads for me to think it can just be a results of these certain roads which to the eye don't seem much different.
Has anyone got any experience or ideas on what this could be? Failing this i have it booked in for rear brakes on the 21st Nov so they can have quick look over the front brake and suspension set up then. Main thing i can think to try now is switch a friend identical wheels with runflats on to mine again and see if the vibration is still there.
Thanks in advance.
Thanks in advance.
