Very small dent
oo7ml
Active member
Hi, I noticed a very small dent on the roof of my car (strange that it is on my roof), it is about an inch in diameter and not very deep to be honest which is the main reason it leads to my post...
The dent looks like it could just be easily pulled out with the right tool / contraption... it is very shallow however it is annoying me and I am sure it could be a small DIY job... has anyone ever repaired a small dent like this before, thanks in advance...
Call a paintless dent repair person. I've used them twice and was amazed how well they did. You might get a lead on a good one from a new car dealer as they use them all the time.
I read somewhere you can use dry ice and they pull out. There was a video on YouTube and it seemed to work.
Not sure where you can source dry ice though
Let an expert do it. They will likely use a sticky pad on something like a slide hammer and just a couple of taps then it's gone.
Watched guys doing it last year and was amazing
+1. don't do it yourself, you will most likely make it worse. It takes years of parctice to bump out a bump the correct way. There are dozens of methods that apply. It a €30 job.
