Various E85/6 trim pieces
TomK said:
dgmx5 said:
Hi there
Would you take £7 posted to the UK for the Under handbrake trim - 51167026223.
I'd rather take the offer below for what I assume is my asking price.
Jamie-innes said:
I'll take the under handbrake trim if still available?
You're welcome to it if you like, can post on monday. Call it £10 delivered.
Deal, i snapped mine changing the centre console :oops: I'll send a PM
Argenta said:
Is the (top) steering column cover still available?
I never got an answer really.
I did reply a month or so ago :?
Argenta said:
So what was the postage for the steering column panel?
TomK said:
Sorry my bad, totally forgot. I've just checked and it looks to be about £12 on a 5+ day.
Rear storage cover, gear stick surround, airbag still available.
Also a bnib clear side indicator (unfortunately I have lost the rubber gasket but your existing one would be just fine) £15 delivered.
Will take this, I've PM'd you :thumbsup:
Hi Tom
My cover is marked do will take this if it's not. My only issue is i can't see how i would remove existing and replace with 'new'. There are no obvious screws etc. It looks like some of that plastic work has been removed previously...welcome any tips :thumbsup:
Hi received, thanks TomK.
Z4paul do you mean remove the light unit? Or the bmw emblem? The light piece will twist out, to the left AFAIK. I’d advise you spray some wd-40 this will help lubricate.
Hi Tom
Hi Paul,
I'm guessing you mean the rear storage compartment cover?
If so there are 2 tiny screws to release around the bearing and then pull out at a 45 degree quite forcefully....
I dont see a light unit? I just mean the rear storage cover itself. I can see that it's hinged but not sure how i would remove that to replace. Busy looking at you tube for pointers :thumbsup:
TomK said:
Hi Tom
Hi Paul,
Brilliant, helpful pic Tom. Mine seems to work fine in that it moves freely snd latches and unlatches but it is minus the tiny screws ? I wonder if previous owner has removed but then glued these bits together...
Yes the cover is unmarked. If you don't have the screws you can get the from BMW of course or anywhere else really...
bmw part number 07119904982 - Countersunk screw, M2 5x0.45x10mm
I still have mine knocking about somewhere I think if you get really stuck, but in storage.
Anyway, drop me a pm if you want to buy it.
My mistake! :oops:
kis said:
My mistake! :oops:
No problem at all, thanks for taking the time :thumbsup:
