Do the helper springs not go at the top?Vanne said:
Interesting never seen suspension you can fit either way before! Certainly different that! I'd fit them the other way to protect the damper rod from picking up damage?Vanne said:They are at the top, these are in inverted. Lol..have to still see which way they will be installed once the wheel is on properly installed. (They are only loosely installed at this stage and only to stop the suspension arm from hanging) but to answer your question, helper springs can go either place. Top or bottom. And these shocks can also be installed either way, upside down or right way up, just depends on how you fit them and for what reason. These have provision for remote canisters, and as such would be upside down, but as I have no need for that, leaves me open to install which ever way I like.
Which might even be this way as the main body will see less fod this way.
Thought so, same here, bad times, lots going over here too, it'll be back though!Vanne said:Yup, sadly as it's probably the worst sector to be in ever. All of mates have gotten fired over the last 8 months.I'll have a look see after my wheels are fitted, depending on clearance.
Liam22 said:Love that ARB! I've been rethinking my setup recently. Do you know if your supplier has hollow/adjustable bars for the OEM pickup points?
Liam22 said:Interesting - thanks Jono. I have a 21mm RARB at the moment. Assuming I can get out for some pre-season testing I'll disconnect it and see what happens.
Ironically, I replaced the drop link bushes and painted the brackets over the weekend!
Liam22 said:FWIW, the E46 M3 CSL uses a 30.8mm front ARB - and it's hollow!
