Hi all,
I have a 2.0i E85, and I noticed some smoke from the engine bay, which turned out to be oil dripping onto the exhaust from the vacuum pump above. Please see attached pictures.
I’m aware the seals sometimes go on the vacuum pump, but I thought it seemed odd that the short hose above this also seemed oily. I’ve just removed this hose (the one to the brake servo) to find a bit of oil inside. Is it normal for the seals on the pump to fail and cause oil to get into the hose?
The brakes are working fine I believe, it doesn't seem to be losing crazy amounts of oil (not topped up since service 8 months ago), no error codes. I’ve had a bit of a rough idle for a while (probably unrelated?), which I’ve been trying to get to the bottom of recently.
Thanks for the help.
