vacuum canister oil change on an N 20 engine
ange5
 New York
Why manufacturers just dont use dip sticks is beyond me. The only way to enter the engine to use the vacuum tube is via oil filter connection. Suspect it could work but has anyone had success done this?
On a N20 engine I doubt if you could get any meaningful extraction of oil without using the drain plug...since you should change the filter anyway where's the drama?
