USB port in glove box not reading any USB drives?
Kolobos
 Scunthorpe
OK, so now I've got used to my new car I'm trying to copy music to the 12gb HDD Jukebox and the USB drive in the glovebox is not being recognised? The port has USB power but is not reading the USB drive?The arm rest USB port recognises the USB drive and plays music from it OK just not the glovebox.
The Cd/DVD player works ok and is copying audio tracks onto the Jukebox OK. Does anyone know what is wrong or is the USB port something that is a regular fault? (update: I think iDrive sees this drive as a backup drive only)
Steve.
UPDATE:
The USB drive has been formatted to FAT32 and is 8gb in size and I've copied 15 albums etc., to it.
iDrive has copied a CD to the Jukebox and also backed it up to the USB drive in the glovebox. I've now asked it to copy data from the USB drive it has now called USB1 to the Jukebox and it appears to be working. What a lark this has been! Why did iDrive report no USB device connected and then backup music to it? How pathetic, has anyone else had these issues.
I provide technical support as part of my job and this scenario is utterly nonsense 🤔
UPDATE 2:
Having time to digest what has been happening here, I believe the glovebox USB port is for a backup drive only and it will backup the music collection to a USB drive and will only copy everything from a USB drive all at once to the iDrive system, and then keeps all the albums in one folder and in the albums respective folder. Good and Bad points to this, at the end of the day I now have my music on the Jukebox. Going forward I may try putting a large capacity USB drive in the armrest and just update that regularly instead :)
The USB port in the glove box is the way forward...simplest is to use an iPhone..
If you use a usb device be aware of total track limit based on the 4 usb devices inserted..
If you have problems with artwork and playlists ‘a clear’ needs to be done...I can explain it] if required
My understanding is that the USB drive in the glovebox is for iDrive updates ONLY so wouldn't recognise drives that don't have map data on them. The one in the centre arm rest is the one you need to use.
iDrive suggests that I use the USB drive in the glove box to upload music to the Jukebox and will not copy them from the USB port in the armrest.
Also noticed that when music is copied it creates one folder with all other folders embedded in it and whilst they do play OK the album art does not function. The solution I believe is to copy one album at a time (only put one on the USB drive at a time, rather than a multiple upload). I will test this over the weekend.
Steve.
Copying music onto the jukebox is OK if your not bothered about album art. Copying one album at a time makes no difference nor does just copying an album not in a folder but with album art.
Conclusion:
I'm going to stick with using a 16gb USB drive in the centre console, updating when necessary as the album art feature works OK here.
Steve.
Conclusion:
Steve.
You can also then keep your original playlists as well :thumbsup:
That's what I do. Miniature 64gb usb stick permanently left in, with maybe 300 albums on it. :thumbsup:
I don't need to use the hard drive. I do exactly the same in my 530d. Only downside is the idrive functionality in the Z4 is not as good as the 530, so playing an album is not as straightforward.
