**URGENT** - Driver's window button not working
As the title really.
The driver's door opens and the window drops as normal, but once I'm in and the door is closed, the window doesn't roll down at all. When i try the window switch I think I can hear a quiet click from the switch, but no actio .
Passenger side works fine and I've tried the 5 second window reset procedure :(
I would try the switch first.
I presume if you hold the unlock button on the fob the window does drop though (coding dependant)
Panic over I think. It may be a dodgy switch. I don't have a voltage tester to check it so will get one at some point.
Left it for a couple of hours, went out just now and tried opening the windows remotely with the key and it worked. Got in, took it for a short drive and all working as normal now.
Every German car I've owned has had electrical gremlins lol. Something to keep an eye on.
