UNSETTLE NOISE FROM Z4 M COUPE'
dalmat
I have Z4M Coupé since 1.5 years.
I do experience unsettle noise coming from back hood.
I have the impression noise is due to slide/rub plastic, and when radio or cd are off the sensation is of a crap car... :cry:
Same, another nasty noise from right electric window when up...I believe when window touches fabric/plastic.
Do you have any suggestion to impreove this aspect?
thanks
dalmat
have you tried lifting the shelf in the boot? i had a big rattle the other day and moved it up to find that it stopped, only to then see the Mobility Kit was rattling against it..
is it the same with the hood up or down ?
what kind of noise is the window? I recently had my roof adjusted by warranty as it wasn't sealing the window properly, leaving a dodgy wind noise problem but all is now cured..
good luck =)
I try to move the mobility kit as you told, but it not that....
I see from pic you have cabriolet, mine is coupé and the problem is there.
The plastic covering the back hood touches the Z body and the plastic itself.... :x
I will buy some fabric and thickness the space between the car and plastic to avoid noise.
dalmat
