Unknown Connector?
ann.nonco
Hi All, while I was trying to fix my roof today when looking under the carpet inside the boot I found these three unplugged connectors.
FU4F4uX
https://imgur.com/a/FU4F4uX
Would anyone know what these three are?
These seems to be an audio cable (bmw blue?) if I'm not mistaken but I can't find any suitableĀ ends for these and they don't fit each other.
Thank you!
Is that on the LH side?
If the car is an early build (pre-October 04) it will have all the looms in there for everything.
I think those are for the amp that sits on the left side of the rear bulkhead if you have the top level stereo system.
Or possibly, if you don't have the CD multi-changer then the two black ones could be for that, but they are usually more central?
The CD changer ones are central and are taped down as I have done a few Intravee installations there and used those cables
Thank you for all of your replies!
My E85 is a October 2003 production model (which is pre-oct 2004) it might be extra wiring then!
It was on the centre so it isn't specifically LH side but the wires did originate from the left side of the vehicle.
My car also had a S692 Preparation, BMW 6-CD Changer I-Bus option so maybe this were the cables in question.
Question solved!
Thank you so much!
Question solved!
Thank you so much!
Out of interest you could get a bluemusic Bluetooth adapter to connect to those two black plugs so you can play music from your phone.
Question solved!
Thank you so much!
I have ordered an Aliexpress harness (that includes a microphone and reciever) for the Business CD unit and it is on it's way!
The 2003 unit didn't come with the AUX option so it was either a AUX retrofit or a bluetooth which I opted for the latter.
