D DMC63 Active member London Dec 16, 2016 #1 I've taken the drivers side door panel off. 2003 z4. I've removed the connector to the window switches but I can't work out how to remove the wing mirror connector from the back of the switch. It doesn't seem to just pull out. Anyone know how?
M markplant Veteran Sheffield Dec 16, 2016 #2 I think there's a tab you push in slightly an then a the arm goes through 90' a bit like a retaining clip
D DMC63 Active member London Dec 16, 2016 #4 markplant said: I think there's a tab you push in slightly an then a the arm goes through 90' a bit like a retaining clip Click to expand... Many thanks markplant. It had me completely baffled
