Tyres
Vivian12
I have a 2003 with a 2.5 engine.
I just wonder what other owners have by way of tyres.
Mine are 225 50 r16 92v.are other sizes suitable.by Potenza.
Size wise, if you want to stick with the 16 inch wheels you've got, then you are stuck with replacing with the same size. Many have changed from runflats to improve ride quality, but this may not be an issue for you as you already have generous sidewall depth which probably helps take the edge off the harshness. If you want to stick with the runflats, then there will be better quality tyres than the potenzas, which are relatively old tech. Loads of recommendations on here for various tyre brands - try a search or provide more specific info about what your budget is etc?
Thanks for the reply.
I obviously need to research this much more.firstlt I’d better start by finding out what
Actual wheels I v got,.run flat do seem to be a better option
V
