Scubaregs
Veteran
Nanu said:Mates rates or for the great unwashed also?
Staff discount mate.
Nanu said:That figures.
Perhaps they may not notice if we swapped cars for a day when I need new ones :roll:
Argyll Andy said:Conti 7’s for both price and performance. I got mine on offer at kwik fit for £650 ish for a full set. Much quieter than all Michelins I’ve had and don’t need the heat the PSS’s did too grip
ori said:Argyll Andy said:Conti 7’s for both price and performance. I got mine on offer at kwik fit for £650 ish for a full set. Much quieter than all Michelins I’ve had and don’t need the heat the PSS’s did too grip
Seeing as I will need nee tyres soon, I’m bumping this.
Andy. Did you get the conti sports contact 7 or premium contact 7?
Argyll Andy said:ori said:Argyll Andy said:Conti 7’s for both price and performance. I got mine on offer at kwik fit for £650 ish for a full set. Much quieter than all Michelins I’ve had and don’t need the heat the PSS’s did too grip
First ones Ori
Got £30 odd cashback through Quidco so a good price
ori said:Argyll Andy said:ori said:Seeing as I will need nee tyres soon, I’m bumping this.
First ones Ori
Apparently they are worse for fuel consumption, but better grip.![]()
Argyll Andy said:ori said:Argyll Andy said:First ones Ori
Fuel consumption is never a consideration for me when getting tyres for the Zed, on the other hand, facing in the correct direction is a priority![]()
Nanu said:Thats a good price for the rears. I have seen the same advertised for as much as £60 more each.
Will be needing 2 new rears in about another 1K or so. Will definitely be putting on the Conti 7s from all the good feedback.
Wonder if it will balance the fuel consumption concerns by having the new Conti 7s on the rear and having the Michelins still on the front for another 10k miles thats left on them?
There is nothing wrong with the grip on the fronts. It will just mean fronts good rears better. No intention of spending nearly £300 to replace perfectly good tyresB21 said:Nanu said:Thats a good price for the rears. I have seen the same advertised for as much as £60 more each.
The difference in fuel consumption must be relatively marginal…I’d be more concerned with having some less grippy front tyres for 10k miles..![]()
Nanu said:There is nothing wrong with the grip on the fronts. It will just mean fronts good rears better. No intention of spending nearly £300 to replace perfectly good tyresB21 said:Nanu said:Thats a good price for the rears. I have seen the same advertised for as much as £60 more each.
Have you just replaced the rears with the Conti 7s? What do you have on the fronts?ori said:Just replaced my rears with continental sport contact 7.
What a difference. I can actually accelerate without spinning the wheels. I mean I could with the mits, but they required me to warm them up.
You were right argyle Andy. Should have done it a long time ago!
Schaef said:Nanu said:Thats a good price for the rears. I have seen the same advertised for as much as £60 more each.
When my rear tires were worn out I switched to Pirelli. I have had quite a few problems with the tracking system with Michelins at the front and Pirelli tires at the rear. Every bend I took a little faster than normal, the car started to correct the car via the brakes, even though I was not going extremely fast. Very weird. Then I replaced the front tires for Pirelli and then this problem was over. I think it has to do with the sidewall of the tire, where Michelin's are a bit firmer than Pirelli's, which makes the car think that the car is going to break away.
That is my experience with two different brands of tires front and rear.
q96169we said:Schaef said:Nanu said:Thats a good price for the rears. I have seen the same advertised for as much as £60 more each.
I think the main issue is the different front and rear tyre size (assume you have 255 front and 275 rear). The tyre size spec allows some variation even if both tyres are 275/35R19. For example, my G31 rear is same size as G29 but one with p-zero and the other is MPSS. When I put them side by side, visually, the p-zero is much narrower than the MPSS despite both are 275/35R19. Usually, same brand same model of tyre stick to the same variation but different brand or different model of tyre will have different variation. Consequently, if you mix tyres front and rear, the DSC wheel speed sensor will read a value that can make the ECU think it needs to do some correction, as the ECU does not know you've put different tyre on. As the ECU is only callibrated to the star-marked defined tyre size variation, in theory, if your front and rear tyres are different brand but all are star-marked, this issue should go away.
Nanu said:Have you just replaced the rears with the Conti 7s? What do you have on the fronts?ori said:Just replaced my rears with continental sport contact 7.
I’ve only replaced the rears for now. My fronts still have 4mm of tread so I’ll replace when needed. Still on pilot sports up front.
