Hi,
I was thinking of changing my tyres from run flats to non RF but at the same time wanted to increase the thickness of the walls for more comfort.
I understand that going from RF to NRF will make a big improvement but I wanted to get your advice on the way forward with respect to tyre wall thickness.
Current Set up:
Front: 225/35 R19
Back: 255/30 R19
Option 1:
Front: 225/35 R19
Back: 255/35 R19
Option 2:
Front: 225/40 R19
Back: 255/40 R19
Option 2 does not appear to be mentioned anywhere in the forums and perhaps not possible without other negative results?
I ran Option in willitfit.com and it indicated that the accuracy of the speedo will be affected?
So can either of these be done and if so what are the good and bad points of each or should they be avoided altogether and I should stick to the original sizes?
I am about to place an order for some Vredstein Ultrac Vorti (seems to be a favourite on the forum) and just wanted to get this cleared up before committing!
Thanks!
Current Set up:
Front: 225/35 R19
Back: 255/30 R19
Option 1:
Front: 225/35 R19
Back: 255/35 R19
Option 2:
Front: 225/40 R19
Back: 255/40 R19
Thanks!
