mcbutler said:same as runflats, side wall stiffness plays no part in pressures, its all about getting the right pressure to get even tread contact across the tyre widthmkinternet said:So having ditched run-flats sometime ago and running 19” rims what would you say should be the correct tyre pressures front and rear?
Generally only me and no luggage - would welcome your thoughts !!!
You are not entirely correct, tyre pressures are based on a number of different criteria, including the mass of the vehicle and the width of the tyre, that's why your vehicle has different pressures for different loadings. This is why the G29 with 255 front & 275 rears has lower inflation pressures than the e89 with 225/255 and why formula 1 cars run about 1.1 bar
The tyre wall is the part that separates the wheel from the road and helps to supports the mass, either wholly or in part and thus also is an influence on tyre pressures.
