I’ve been running my rear tyres at 32 psi but I’ve noticed that they are significantly more worn in the centre than at the edges indicating that they are over inflated. A lot of people seem to run their tyres at higher pressures than this so do you sacrifice tyre wear for handling or should they actually be run at much lower pressures than people think to even out the wear? Is it tyre make dependant or will all tyres of the same size wear the same way?
