Tyre pressure recommendations please!
James93
Just bought my z4 already with good year eagle f1s on the rear and good year efficient grip on the front... just wondering what pressures I should use as the mixed opinions are confusing me a little
Cheers,
James
Always run mine at 2.1 bar front and 2.3 bar rear (30psi /33psi) as per the sticker in the drivers side door shut :thumbsup: Screenshot (7).png
I run my Pilot 4s at 36 front 38 rear. I'm just 3000 miles into them but ride, handling, and wear are all excellent.
All depends on what sort of driving your doing with the car.
Is it just for weekend fun, commuting or a bit of both?
The harder you drive the higher the temperature in the tyres. The higher temperature in the tyres, the lower the pressure you can go from cold as the heat increases the pressure in the tyres.
