abzthemanc
So bought my Z in August a 3.0 pre facelift (04 plate), two months of ownership in and have not driven it half as much as I would have liked but still been so so much fun, even with fairly budget tyres. I'll probably replace with PS4s when due.
I'm essentially using it as my daily now. The boot has been surprisingly resourceful!
Im currently averaging 18mpg around town and about 30mpg when taking on the motorway, maybe slightly higher... is this par for the course?
There have been no major issues to be honest so generally very happy however I have identified a few niggles here and there. If you have any advice or pointers to existing threads on similar issues then would be very grateful!
Got my first service booked in at Darren Wood in Stockport, but next year may attempt doing it myself.
- Roof used to open from key, doesn't appear to now... not an issue at all, but now sometimes when I open the driver door, instead of the window just going down a few cm, it goes all the way down...and back up again following closing the door... livable but annoying and unnecessary wear on the window motor for my liking
- Airbag light is on - new sensor required or something else to try first? Do i need a code reader to clear the light?
- The hard covering for the back of the drivers seat.. has come loose and doesnt stay put... i wanna fix it back on to the seat.. any tips? Couple of dabs or glue be ok or is there a better solution?
- Got the small stubby aerial and radio reception is a bit ropey at times... (Or i could have forgotten how bad it was in a car that is > 15 years old...) is it worth changing the aerial?
- There's some small areas of rust I've identified, a couple of hints of it under a couple of wheel arches, and the boot pistons have a bit more, from the water draining through. Want to address these, any tips? For the piston is it just a case of sand/remove what rust I can and paint over?
- Loving life using a CD player again after so long! However, for improved SQ should I first replace the HU or replace speakers instead?
- Getting squeaky steering at parking speeds, is this anything to be wary of or needing lubc=ricant, is it normal for this age of car?
