Turning off the Stop / Start Cap(Dis)ability
I must have had stop/start Carly'd out by previous owner :D
I get this when stopped and in neutral.
Carly doesn’t give you that display, as far as I’m aware that’s displayed if the battery is below the required charge level or the cars not up to temp (which it looks like it is) :thumbsup:
Hhhmm i don't know realy, however battery is a new AGM and just back from a 20 min drive home for work ? :?
Checked and mine is remember the setting from before the engine was stopped, so leave it activated when you turn the engine off and it will be activated on next startup (which is the default config) or leave it deactivated when turning engine off and it will be deactivated when you next start the engine.
Not sure if there is an option to just disable it completely but having it remember the last state seems right to me, at least you could still activate it if you wanted to.
