Well, not surprising but the floor of the trunk above the muffler gets rather warm on a long drive. Since that is where I keep my ice chest (spare tire is on the other side) this doesn't bode well for the ice etc. inside.
I'm experimenting with some thermal insulation pad (foil faced fiberglass sheet approx 1/4" thick) that's good to 900 f reflective. I dropped the muffler and existing heat shield tonight and put a layer of this insulation between it (heat shield) and the trunk floor. I also added some to the shield under the passenger floor (gets hot too) to see if it helps.
Has anyone else attempted to insulate these areas? I'm curious what else has been done and what was used effectively.
