Trouble-shooting intermittent "no-crank, no-start"
Z4Mariner
 Minnesota
Hi -
Posting this as a mid-point in tracing and resolving an intermittent "no-crank, no-start" issue with two similar 2006 Z4's, both with three pedals. One is my '06 Z4C (E86) and the other is my friend's '06 Z4R (E85). My friend's roadster has had the ignition switch and the starter replaced, but he still has a 'once-in-a-while' no-crank, no-start. My coupe has experienced a similar intermittent issue, and we have compared notes. These are US spec cars, and the cars will not start unless the clutch is depressed - I am unsure whether this is true for non-US 2006 spec Z4's.
I have inspected the engine ground strap - I removed, cleaned contact areas and nuts, and re-installed it (strap itself is perfect). I replaced the ignition switch, but found that it had already been replaced (disturbed red paint) at some point. After putting the new one in I can report two things: a) the old switch contacts seemed in good condition when I disassembled the switch, b) I don't think that I've had a no-crank event since I did this. Unfortunately, intermittent failures are frustrating because it's hard to know when they've been truly solved or not - so MAYBE a new switch fixed my issue or MAYBE the problem is not solved, and I just don't know it yet. :wink:
Since I drive the car daily in the Summer, and the starter is now at 98K miles, I bought a new Bosch unit to install and a new Clutch Switch. I'm replacing both items on age and mileage. When done, I will inspect / test each of those originals and report on what I find. The Clutch Switch seems to be a Hall effect solid-state design, though with age it may have gotten marginal on responding to the clutch piston position.
UK spec E85/86s don't need the clutch depressed to use the starter thankfully - although my E90 does. :(
My second E86 was sometimes a bit slow cranking when it was up to temperature but never failed to crank. Then not long after that it needed a new battery which solved that issue.
But that doesn't sound like your problem, so I hope you can resolve it. :thumbsup:
Update - I have a new Bosch starter and a replacement clutch switch in hand. However, I have not have a single "no-click, no-start" in the two weeks since I removed and cleaned the engine ground strap and installed a new ignition switch. Though the old ignition switch guts appeared in very good shape, that may have been the issue. I will continue to drive until I need to store the Z4 for the Winter and report back again then.
Either way, I'll probably make the new starter a Winter project, just for peace of mind. The clutch switch too, since it is such an easy install. As mentioned before, I'll test each part (including the old ignition switch).
