Hi forumers, I need a little help. At the weekend I’ve noticed that a small piece of trim is missing but I’ve no idea what to call it or describe it to get a replacement ordered, so hoping someone can help…
Inside the rear wheel arches of the e89 at the front, tucked low and behind the side skirt panel, should be a piece of inner arch trim that covers the trailing arm and fits up to the main arch liner. I assume it’s held in place with some sort of clip(s) and a pot hole or puddle has removed it, so I’ve now got a hole!
It’s hopefully a cheap fix. Did get last night getting a pic but it didn’t help. Will try again later if it helps diagnose the part I need to go out and get. Also hoping, as it clearly came off easily, I can easily self fix a replacement back in.
Screwdriver at the ready. Have a good day, and thanks for any help. JL
