Trifecta lights.
streamin
New member
Hello I'm trying to figure out my trifecta light problem. Cars steering feels iffy as well. When turning it seems to want to stay at the position of the turn instead of normal where the wheel will bounce back and continue straight. (If that makes sense) I took a video of a potential problem with the steering rack and maybe that has to do with the lights but obviously a steering angle sensor could be the culprit too. Hopefully someone can shed some light. My obd port seems to not want to communicate with my scanner either. I have read that someone unplugged their SAS after the trifecta lights and their scanner was then able to communicate so that will be my next step.
https://photos.app.goo.gl/WzQTNEevxj51uSEP6 this is the video to a potential problem? Normally I feel like any play is bad so this doesn't seem right. Possible issue with steering rack
Hi.
From recent experience I know full well that steering issues will trigger the trifectas.
They'd been lighting up my dash for weeks, it seems due to worn bushes & bad tracking.
My mechanic has just replaced the tie rod assemblies which had seized and could not be adjusted.
He'd previously replaced shocks, control arms and various bushes as well.
Steering is now true again and not pulling to one side as it did before.
Getting rid of the trifectas was the icing on the cake :D .
