Transverse Acceleration Sensor
Charjo
New member
Problems with the three lights. I have tested for a malfunctioning Transverse Acceleration Sensor. I have confirmed the ABS system in working properly. The direction I have found said to test the plug to the sensor - terminal 3 should be battery volts 12v and terminal 5 should be 0 volts. Terminal 3 shows 0.30 volts and terminal 5 is correct at 0. Any suggestions on where to look. Where is the 12v power supplied from? I have checked fuses.
