Or the bypass plunger is pushed inRozzy1970 said:[ref]enuff_zed[/ref], The motor is still going, checked connections and all seem tight so working on the basis that a seal has failed
enuff_zed said:[ref]Rozzy1970[/ref], you could simply buy yourself this:
https://www.ebay.co.uk/itm/154021453500
Install it on an old laptop (I got a cheapo Windows 8 one). Then you have a code reader, fault reseter and coding options.
You'd probably quickly recoup your outlay by doing stuff for others in your area.
No, it's a standalone bit of software, with it's own cable.RAYK47 said:enuff_zed said:[ref]Rozzy1970[/ref], you could simply buy yourself this:
Do you need ISTA (or whatever its called) for this?
Listers BMW, Kings Lynn, quoted one hour labour @ £186, just to put the car on a diagnostic machine, even though the owner already told them it was the SIM85 failed.Rockhopper said:Most dealers will charge a minimum of an hours labour to do anything on your car even if it only takes five minutes..
