Hi everyone new owner here.
Recently bought my first Z4 as a summer toy.It is a 2003 2.5 auto and so far love it to bits.
It does however have a fault.It has happened maybe 4/5 times in the last month and only happens first thing in the morning.I turn on the ignition and all the warning lights come on then go out as expected but on these few occasions the transmission light stays on.If i start the engine then just move the gear lever through the gears turn the car off again then start it up again all is ok again.So it appears the car knows/thinks there is a fault before i have even started it.I am sort of suspecting low gearbox oil and am planning to have a filter/oil change done but wondered if any of you may have other ideas.
Thanks in advance.
Sean
Thanks in advance.
Sean
