Transmission telltale light intermittent on
dave1814
 Sheffield
Hi Guys,
I have an issue where by the transmission telltale light comes on randomly (usually when the car has been left overnight). When I restart the engine it disappears. I haven't noticed any issues with driving the car, however my problem sounds similar to this one here...
http://z4-forum.com/forum/viewtopic.php?f=3&t=16876&p=455432&hilit=transmission+switch#p455432
I have read the error codes and get this....
E R R O R M E M O R Y R E P O R T
Date: 08/17/13 17:43:06
ECU: GS8604
JobStatus: OKAY
Variant: GS8604
RESULT: 1 errors in error memory !
60 Gearbox Switch
Error frequency : 4
Logistic counter: 0
Error occured 1. times at:
Mileage/Km-reading 63560.00 km
Gearbox Switch L1 0.00 0/1
Gearbox Switch L2 1.00 0/1
Gearbox Switch L3 0.00 0/1
Gearbox Switch L4 1.00 0/1
Prog.-button A 1.00 0/1
Prog.-button S/M 1.00 0/1
Steptronic slot 0.00 0/1
Error lamp 0.00 0/1
Output Speed 0.00 rpm
Battery Voltage 12.12 Volt
Error occured 2. times at:
Mileage/Km-reading 63730.00 km
Error lamp 0.00 0/1
Battery Voltage 12.20 Volt
Error occured 3. times at:
Mileage/Km-reading 63890.00 km
Error lamp 0.00 0/1
Plausibility
Sporadic error
Does this look like a dodgy transmission switch?
thanks,
Dave
Possibly, or the related wiring. Check the connector for dirt, corrosion, moisture, etc.
Sorry, I don't even know which switch this is referring to. It just seemed to me a connector on the transmission is more susceptible to moisture damage then the switch itself. However, I believe most of the wiring goes into the hydraulic unit at the rear of the trans, which shouldn't be too hard to access once you're under the car, but I haven't physically seen an auto trans, so I may be wrong. All the other controls and relays are in the electrics box under the bonnet behind the left strut tower so should be fairly safe from moisture.
