Transmission Replaced on 2007 3.0si 6MT
DarKWing
 Mineral, VA
I bought my 3.0si coupe at about 12,000 miles. It was a dealer service loaner, so I expected some issues. When I first drove it, I noticed a bit of a clunk shifting out of first gear. I chalked this up to either the CDV or just my driving, and soon learned to shift by holding the RPMs higher when engaging on the upshift, eliminating the clunk. It didn't bother me too much, and I wasn't in a hurry to have it looked at considering the amount of warranty remaining.
In the course of putting about 6,000 miles on the car, I experienced a few more shifting issues: a couple of times, during stop-and-go crawling in traffic jams, I had a very hard time finding first gear. I had to shift into second, maybe third, playing around with it a bit before first would finally engage. This was bothersome, as it could be a safety issue to not be able to move while traffic ahead of me is pulling away.
Then I found a problem with third gear: intermittently, and always during fast upshifts, third gear would just refuse to engage, actually grinding and knocking the shifter out of my hand in a couple of instances.
This combination of quirks led me to ask a transmission expert (shameless plug for Robert at Gearbox Transmission, http://www.gearboxva.com in Richmond, VA) for his opinion, and he confirmed that Z4s have had third-gear issues, although this was the first time he'd heard of first-gear problems.
A few days later, armed with this information, I took the car to BMW of Fairfax and described the issues. They only had the car for about 20 minutes before the service advisor came out and put me in a loaner car, saying they were opening a PUMA case and likely replacing the transmission.
This was on 8/20/09. The new transmission takes 7 business days to ship from Germany, but it should arrive on Monday 9/31 and hopefully I'll be picking the car up on Tuesday.
The moral of this story: If your Z4's manual transmission feels funny, it's not just the CDV and it's probably not you, assuming you know how to drive a manual. Take the car to the dealer ASAP, and make sure you describe EVERY symptom. There is apparently a manufacturing or design defect with certain transmissions in these cars, and BMW seems to recognize this, based on the expediency with which my issue was addressed.
Can't wait to get it back, they put me in a 2008 X5 4.8i (Premium) - aside from the powerful V8, I am completely underwhelmed. I actually like it less than the 2001 X5 4.4i (Sport + Premium) I used to own. Plus 18.2 mpg is a big difference from the 26.7 mpg I average in the Z4...
This message is cross-posted on several forums, hopefully as a public service to other Z4 owners
DarKWing, thanks for the thorough post!
My 2007 3.0si coupe just passed the 12,000 mile marker, and although I haven't experienced the first gear troubles you describe, I've occasionally noticed third a bit tricky to engage. And being that I live in Richmond, VA, I appreciate your shameless plug for Gearbox T. It's great to know of a respected independent shop.
Best of luck with the new transmission. And if you ever glimpse a slightly darker version (i.e. Jet Black) of your beautiful coupe roaming the Virginia roadways, that might be me.
Cheers!
Coming up on 30K on mine. So far so good. I have noticed these are very tight transmissions-in the parking deck, you can hear every click shifting!
Update on the transmission: it took about 3 weeks to get my car back, but it was worth the wait :D. Mad props to BMW of Fairfax for their consistently good service on the Z4 and my old E39 530i.
I had no idea the shifter was supposed to feel that good... I'm still mystified by this failure, though. After talking to quite a few independent mechanics and dealer reps, I'm thinking it was either a fluke or caused by severe abuse during the car's first 12,000 miles of life as a service loaner.
What I can't figure out is what kind of abuse and improper shifting could have caused the transmission to fail without burning the clutch... Dumping the clutch maybe? Or is that why the CDV is there in the first place? Maybe someone just wanted to shift without using the clutch, like I did when my '78 Corolla's clutch slave cylinder went out on me.
