Transmission fluid pump
Bama_Z4
 Mobile, AL
Can anyone recommend a cheap hand pump that will effectively allow me to top off my low auto transmission fluid? Thanks in advance.
Is it an SMG? The normal five speed auto doesn't have a dipstick although maybe USA market cars had different gearbox option to the UK. The normal method is to squirt it in though the fill hole until it just trickles back out but to check it at temp as well.
1) The transmission fluid temperature must be between 30°C and 35°C before checking can begin. Use test equipment to determine the trans temperature.
2) The vehicle must be level with engine running at idle speed and air conditioning turned on.
3) Step on the brakes firmly, apply parking brake fully and shift to D and R, briefly pausing in each position before shifting back to the Park position.
4) With the engine running at idle speed and the selector in Park position, remove the filler plug. Monitor the transmission temperature, if a small stream of oil runs out at 40°C, the fluid level is correct.
5) If no oil runs out when the filler plug is removed, the fluid level is too low and oil needs to be added until it overflows.
6) With engine running, install the oil filler plug and tighten to proper torque.
Just Google it. Hand pump or pressure, whatever you prefer.
