I was wandering if the Red Line D4 ATF fluid is good for the 2.5i manual tranny as well... That's what I used in the Z3 and the two have the same transmission so I should be fine... But wanted to make sure...
Also, did anyone has any recommendation on some tread sealant for the drain and fill plugs... Using Teflon tape is not recommended as some people had their transmission case cracked because of the extra pressure so I was thinking about a liquid sealant to apply to the bolt.
