Transmission Fluid Leak at Mechatronics electrical connector
NZ00Z3
 Timaru New Zealand
My 2007 3.0SI E86 coupe with the 6HP19 auto transmission has a leak coming from the electrical connector on the Mechatronics. I have the ZF transmission service kit and the new Mechatronics connector sealing sleeve.
Getting under the car, there looks to be next to no space to get to the electrical connector, yet alone replace the sealing sleeve.
What have people done to make the job easier and get access?
you have to remove the oil pan and there is an unlock lever you have to pull to release and pull out to replace the sleeve. Since you are already there, replace bridge seal as well.
you have to remove the bracket that connects transmission and exhaust, it gives you more space to put your hand on the connector shell and unlock it by turning it anti clockwise.
After a lot of research on the Web and NewTIS, I came up with a plan. Remove the transmission cross member to get enough space to access the electrical connector and seal.
Sounds easy, but it is a bear of a job.
So far I've removed:
- Front reinforcement panel to gain access for the transmission support jack
- Rear reinforcement plate
- One rear cross brace
- Whole exhaust system
- Several heat shields
The above was just to get access to the cross member.
- Cross member removed
- Electrical connection disconnected, just enough hand room.
- Transmission fill plug loosened, this was so tight I worried about breaking the 8mm Allen key
- Transmission drained
This is as far as I've got today. Will resume the geriatric gymnastics under the car tomorrow to replace the electrical plug seal, mechatronics seals and put the whole car back together.
The transmission seal and the mechatronic connector seals where replaced and everything put back together.
Took 2 1/2 , 6 hour days (15 hours) to complete. Slow but meticulous.
